Rough idle pls help
Discussion in 'General Tech and Maintenance' started by chilli_822, Apr 6, 2004.
  1. chilli_822
    chilli_822 Junior Member
    i just bought a 95 civic ls. i have never messed with the automatic tranny before and im not sure if that is the problem. when u shift into drive, drive a little ways then stop the rpms drop low and it begins to idle rough. it wont idle back up until u give some gas. and the car kinda shakes when it does this. it does not do it in park or when u first shift into gear just after it drives a little. any help would be great.
  2. chilli_822
    cmon dont be shy. give it a shot
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    no one has automatics :) How is your tune up stuff, like air filter, stuff like that?
  4. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    turn idle up. car wont drop low enough to idle rough=problem solved. theres like 5 ppl on here that have autos, so most of us dont know much about them...
  5. chilli_822
    thanx for the help im replacing all filters and stuff right now. it just seems weird that it only does it in drive and only after u actually drive it for a little while
  6. Import Builders
    Import Builders Senior Member
    LA, California
    its a flathead screwdriver on your throttle body somewhere, loosen it slightly.
    Jeff
  7. v13tl2omeo408
    v13tl2omeo408 Member
    yes.
    They Few, The Proud, The Automatics
