rpm nidle jumping
Discussion in 'Engine Building' started by possessedimports, Sep 13, 2003.
  1. possessedimports
    possessedimports Member
    eastsider
    i have a 91 integra with a jdm b16 in it and last night i was driving on the parkway and when i looked at my tachometer i seen it jumping.it didnt have any effect on the way the car was driving. what can make that happen :hmm:
  2. All Show
    All Show Member
    Vacuum leak? Not sure but that is my guess.
  3. dmxbmx
    dmxbmx Junior Member
    new jersey
    ive had that happen plenty of times...i can recally driving down rt 46 and having that happen...check all the vacume lines and even check your sensors...i had a sensor fall out once and the idle bounced
  4. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
  5. brian11to1
    brian11to1 Senior Member
    He said it didnt effect the way his car ran, so it has to be Electronic correct? If not then Im lost, sorry if I confused everyone
  6. Iquark
    Iquark Senior Member
    Mount Vernon, WA
    Did you hear the engine changing RPMs, or was it just the needle that was bouncing?
  7. 5th gen civic
    5th gen civic Member
    COLUMBUS OHIO
  8. hybrid89
    hybrid89 thistownsucks...
    SoCal
    Almost garaunteed that it is one of your ignitor conections inside the distributor. Rip the cap of the distro and check all the connections.
  9. Cashizslick
    The same thing happened to me, i replaced the igniter in my distributor and the problem was fixed.
  10. possessedimports
    eastsider
    where s that and yesturday i was on the highway and i seen it jumping again. it starts around 3500 and stops 4500.
