RPM signal
Discussion in 'Civic and del Sol - EG and EK' started by civiclxb16, Aug 19, 2006.
  1. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    ok i had a code 22 and i fixed that. went for a spin and no vtec! and i made a discovrey. the tach was not working and i was thinking that maybe there is no rpm signal. now i was wondering what wire from the dizzy can i run to the ecu to get direct signal? the motor is a 94 lsvtec the car is a 99 ex. wiring harness is from a 99 si. ecu is a chipped p28. please give me a hand!
  2. sciVici
    sciVici New Member
    wrong ecu. p28 is a d16 vtec ecu. you need a p72 i believe.
  3. civiclxb16
    Poconos pa
    :owned: :newbie: chipped man it worked just fine in a gsr
