RPM, SPEEDOMETER
96EXTO2000SI
I JUST CHANGED MY 96 HONDA CIVIC EX MOTOR TO A 00 HONDA CIVIC SI MOTOR WITH
THE OO HARNESS AND COMPUTER. MY QUESTION... IF YOU CAN HELP ME IS THAT WHEN I
CHANGED THE MOTOR EVERY THING WORKS, THE CAR IS RUNNING PERFECT THE V-TECH
OPENS, THE ONLY THING IS THAT THE SPEEDOMETER, RPM GAGE, FANS, AC
COMPRESSOR, AND REVERSE LIGHT IS NOT FUNCTIONING WHAT MUST I DO TO FIX THIS
PROBLEM?
PLEASE CONTACT ME AS SOON AS POSSIBLE
THANK YOU,
KIKO
Originally posted by 96EXTO2000SI@Aug 5 2004, 09:14 PM
THE CAR IS RUNNING PERFECT THE V-TECH OPENS
[post=373198]Quoted post[/post]​
ooooo big boo boo it is v-tec...lol anyhow your wiring did you use your stock ex wiring? if not you should it is easier to work with beside your car is obd2a and your engine is obd2b and it will have problems like what you are having and get a obd2a-obd2b convertion for the ecu i learned the hard way but you should be using a p28 chipped on your car it works better less error codes and no knock sensor to wire or run i have one already chipped if you want for 170 shipped but if not good luck i would go with the obd2a convertion and use the stock ex harness and just add the knock sensor
if stuff isn't working, chances are you have codes.
pull them.
VSS, and ECT seem to be some problems.
