rpm sticks after giving it
Discussion in 'General Tech and Maintenance' started by rtpassini, Sep 4, 2004.
  1. rtpassini
    rtpassini Member
    after i drive it hard. my rpms will stick. ill put it in neutral and itll stay at like 4500 rpms. i think this may have something to do with my tps and or throttle cable. any opinions?
  2. E_SolSi
    my guess would be throttle cable sticking
  3. rtpassini
    rtpassini Member
    the only thing that makes me wonder is that i was trying to pull out on the gas pedal. and didnt really do much
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    go to the throttle plate and give give crack open the throttle a decent amount and see if it snaps back into place. If not, the return spring or the cable is at fault.
  5. hybrid89
    hybrid89 thistownsucks...
    SoCal
    throttle cable might be alittle too tight.
