X xxji3lazexx 1SIKEK4 Jun 2, 2009 #1 where can i find the wire to connect the green wire with tells the tach its rpm.on a honda civic dx90
efhondakid My name is Byron. Jun 2, 2009 #2 If you pull the gauge cluster look for a solid blue wire that goes into the big plug on the left. Or the solid blue wire coming of the dizzy.
X xxji3lazexx 1SIKEK4 Jun 2, 2009 #3 thankss mann forgot to say it dosent have and rpm gauge in cluster switched to manual
efhondakid My name is Byron. Jun 2, 2009 #4 That wire is still there. I have a DX but switched to an Si cluster, all I did was pull the DX cluster and put the Si right in.
