rs/vtec info obdI head to obdII
Discussion in 'Engine Building' started by 1badteg, Oct 2, 2006.
  1. 1badteg
    1badteg Junior Member
    ive got a 96 rs integra. im in the process of picking up an obdI gsr head (95) and need to know if i can just swap out the vtec sensor on the head and all other sensors to obdII and be good? ive got a p72 obdII ecu as well. anyone willing to part with an obdII vtec sensor cheap?
  2. tartymctang2357
    tartymctang2357 Grand High Wizard
    philadelphia
    yea should be able to swap out all the sensors with the ones you already have in the integra and it'll all be obdII, i'm not sure about this but i don't think the vtec solenoid really matters in the case of obd's i believe they were all the same for all the years, don't quote me on that tho
  3. ef8
    ef8 Junior Member
    Do you mean putting the gsr head parts on the rs head?If so no you cant.
  4. 97CTR
    97CTR Senior Member
    Its called an LS/Vtec. Do a search and you can find out what you will need to put a vtec head on a non-vtec block.
  5. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    I would match the ecu with the head so maybe look for OBD1 P72 ecu.
