rsx-type s motor into 2002 si
Discussion in 'HYBRID -> EG-EK / DC' started by spoonhatch, Dec 20, 2002.
  1. spoonhatch
    spoonhatch Member
    ok my friend just bought the type-s motor, 6 speed tranny, and all. he has a 2002 civic si, does anyone know how much modifications are needed to do this swap, or know any links that explain it?
  2. manic_mechanic
    manic_mechanic Senior Member
    DobbsFerry, NY
    as far as i know it should be a straight swap. thay are basically the same engine, but dont quote me on that.
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    i will find you a link that has stuff about it, the big thing that is a problem is you have to get the engine out through the bottom and you have to change something to allow for the sixth gear.
  4. asmallsol
  5. spoonhatch
    spoonhatch Member
    helps a lot, i'll be sure to let him know about this. thanks
