RUF's New Supercar: CTR3
Discussion in 'Auto Multi-Media' started by dveit, Apr 16, 2007.
  1. dveit
    dveit Well-Known Member VIP
    DMV
    Looks pretty badass! :drool:
    Searched with no results, so I hope this isn't old news...
    Link 1
    Link 2
    Gallery
    RUF CTR 3 Technical data
    Body
    Body build in steel, aluminium and kevlar-carbon. Rollover protection in A-pillar and in birdcage. The birdcage forms a torsion resistant unit with the front chassis by joining to the sill beam and the A pillar.
    Front structure: steel, zinc dipped
    Safety passenger compartment: steel, zinc dipped
    Engine and transmission frame: space frame and birdcage
    Front bonnet and doors: aluminium
    Body shell: Kevlar-Carbon composite
    Engine
    Type: turbocharged boxer
    Cylinders: 6
    Displacement: 3,746 cc / 228.6 in3
    Bore: 102 mm / 4.01 in
    Stroke: 76.4 mm / 3.01 in
    Output: 515 kW (700 hp) at 7,000 rpm
    Max. torque: 890 Nm / 656.5 lb-ft
    Compression ratio: 9.2 : 1
    Engine control unit: Bosch Motronic with OBD-2
    Turbo charger: two KKK turbo chargers
    Intercooler: two air-air-intercoolers
    Transmission
    Power delivery: rear wheel drive
    Transmission: sequential 6-speed-manual transmission, transversal, angle drive, shift indicator in the instrument panel
    Limited slip differential: multi-disc locking differential
    Locking value load / deceleration: 40 % / 60 %
    Chassis
    Front axle: McPherson struts, anti-roll bar
    Rear axle: multilink rear axle, anti-roll bar, horizontal coil over shock absorbers
    Steering: Power assisted rack and pinion
    Brakes
    Brake calipers front/rear: 6 piston fixed light alloy calipers
    Brake discs front/rear: ventilated and cross drilled ceramic composite discs
    Brake disc diameter front/rear: 380 mm / 15 in / 380 mm / 15 in
    Anti-lock braking system: Bosch ABS 8.0
    Wheels and tyres
    Wheels front/rear: 8.5" x 19 / 12.5" x 20
    Tyres front/ rear: 255/35 ZR 19 / 335/30 ZR 20
    Size and weights
    Length: 4,445 mm / 175.0 in
    Width: 1,944 mm / 76.5 in
    Height : 1,200 mm / 47.2 in
    Wheelbase: 2,625 mm / 103.3 in
    Front track: 1,506 mm / 59.3 in
    Rear track: 1,585 mm / 62.4 in
    Empty weight with 6 speed manual transmission
    According to DIN: 1,400 kg / 3,086.4 lbs
    According to EG-standards: 1,475 kg / 3,251.8 lbs
    Performance
    Top speed: 375 kph / 235 mph
    0-100 kph / 0 – 62 mph: 3.2 sec
    Price
    Euro 380,000.00 (plus VAT)
  2. eg6sir
    so its an RUFs version of the Caymen and Carrera GT together.. :drool:
  3. formby
    formby learning in progress
  4. eg6sir
    that thing is soo racist :ph34r:
  5. Celerity
    Celerity Well-Known Member
    I would love two KKKs in the back of my car !
  6. pissedoffsol
    dont worry, the kkk's get replaced all to easy :)
    i'd pimp it.... but not for 500k
