running b16a1?
Discussion in 'HYBRID -> ED-EF / DA' started by HONDA_F1, Jan 18, 2005.
  1. HONDA_F1
    HONDA_F1 Member
    NJ
    is it safe to take to take my b16a1 to 8000rpms or do the springs need to get changed because i've heard that the valves smash into the pistons at high revs ...is this true?
  2. CarAudiophile
    CarAudiophile Senior Member
    Omaha, NE
    My shift point is right at 8K.. I have revved mine 2 9K a couple times..
    But 8K no problem.. Shit I hit that about 20 times when I take my car out..
  3. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    The redline set by factory on the engine is 8200 RPM, so yes, it is definatly safe.
  4. HONDA_F1
    HONDA_F1 Member
    NJ
    lol i know
    but i've just heard people say the springs wear out and lose there strength
    belive me when i take my bro's s2000 out it hits 9k plenty of times...and the rsx type-s we had went into the red alot =)
  5. StarBellieAngel
    StarBellieAngel Senior Member
    San Jose, CA
    i thought the first gen b16s were set at 8k... but i may be wrong. i know that mine is 8200.
    i'm sure it's fine. :) otherwise, i think honda would have done something about it.
  6. brc80
    brc80 Senior Member
    Southern California
    Ive hit 8500+ many times on my first gen without a problem.
  7. HONDA_F1
    HONDA_F1 Member
    NJ
    im not saying its bad ...i know mines set at 8200 as well
    but im asking if everything is able to handle it engin internal wise after sitting around for so long and its age....thats all
    jw if i need to replace anything to be safe
  8. Citizen_Insane
    Minneapolis
    Yes, OEM redlines are set way low so that there is almost no chance of smacking a valve. My b16 is old and I rev that bitch up to 8200 all the time....ahhhh I miss my rex....anyhoots, yes you will be fine reving to 8200 RPM. Normal wear and tear isn't going to make much of a difference in your case.
  9. StarBellieAngel
    San Jose, CA
    yea, it will be alright, if you feel you need to replace whatever you think should be... if it's 'old'
  10. brian11to1
    brian11to1 Senior Member
  11. 5speed4life
    5speed4life Senior Member
    Cleveland Ohio.
    Lol, My dude with tha b16a at the track didnt feel like shifting out of 2nd, and he checked the vafc's history and he hit 9211rpm. lucky he didnt rev higher, b/c he wasnt paying any attenton, and has no rev limiter. if he'd of blown it, atleast we would know where to stop.
  12. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    The important question to answer is where you motor makes power to. If you not making power over 7K, the only reason to rev it that high is the rice factor. Dyno runs can tell you the answer to that question.
  13. HONDA_F1
    HONDA_F1 Member
    NJ
    umm my peak torque(not hp) is at 7k....stock
    are you saying i have compresstion loss or there is something wrong with moter and if thats the case there no reason to rev it that high?
  14. StarBellieAngel
    San Jose, CA
    there isn't a reason to rev it that high, unless your motor makes power up there. and yes, some do. i can 'safely' rev mine to 9, but i don't, because the power just isn't there... plus, i haven't rid myself of the limiter yet.
  15. nfn15037
    nfn15037 Senior Member
    How can you "safely" rev a stock SIR-II to 9k?
  16. StarBellieAngel
    San Jose, CA
    did i say my sir II was stock? no. i'm just mentioning, it's POSSIBLE. is it SMART? no. is it making power?? no. so... that was my point.
