just wondering if i could run my car without the fusebox. here is a little insight of what i have. IT is a crx race car with ls/vtec i have a full obd1 chassis harness and gsr engine harness. i do not have a dash so the chassis harness looks like hell all bundled up on the floorboard and under the pedals. but if i just took the harness running from the ecu to the wire harness junctions and powered the under hood fuse box would i still have all functions that i will need to run the car. i will not be using the ignition switch starter is wired to a push button. any help would be appreciated.
