running either rich or lean
imanoob
OK i know how a car runs and stuff but i dont know alot about running rich and lean and i think that is what is wrong with my car. When i crank it is has a rough idle but when i rev it up white smoke comes out of the exhaust, when i go down the road it doesnt do it and no it is not cause it is cold. does this mean i am running rich or lean OR what? also how do i fix it. I have a 94 integra rs with a drag turbo with vortech fmu. stock injectors and no tuning yet. Thanks to anyone who can hep me
so it that all it is. see i would tune but i am in the process of saveing for 440cc rc injectors and hondata s200
tune, and make sure you have a sound head gasket.
when im driving it is fine but only when im at an idle or under boost (below 3500) it smokes that is the only time
if i was you i would park it till i had hondata and inj and then tune!!! are you really running a stock ecu ? do you even have a a/f gadge? is the block stock? how much boost are you running?
