not throwing any 02 codes or anythig of the sort... but the car seems to run way to rich.... sometimes after leaving from a light or stop at 1/4 throttle it boggs down really bad, until i open it up all the way then runs fine... and when i shift from 1st to second, the car likes to pop/backfire
so i guess my question is, could my coolant temp sensor not be sending the right voltage to the ecu telling the puter that the vehicle is warm and to lean out? or could it be something else?
i have a bit of experiance with Domestic Fi , and i know the car does this when cold.... but not sure if the JDM/Honda ecu runs the same way..... this car has been a wireing nightmare since i purchased it... upon purchase i found that 1 of the harnesses wasnt even hooked up to the ecu fully (kinda crooked with half the pins in) and that EVERY connection from the ecu and to the sensors was crimp capped together(still dont know today how the thing still ran)...theres a freaking mess behind the block that i have yet to sort out... any idea's?
Chris
Chris
