I successfully went dpfi to mpfi. The only problem is Im running so rich. I have no codes. I verified good map and circuits to it. What do I do? can I Regulate the fuel better somehow? What are my options?
Timing is off. Does it have shakey idle? Could be the IACV. Or from the switch you got bigger injectors to do the switch and they don't match up to the fuel maps exactally.
Too many things to call in the air, but try some of those and post back.
