Rust Problems
Discussion in 'General Tech and Maintenance' started by Mr90Civic, Jan 23, 2004.
  1. Mr90Civic
    Mr90Civic Junior Member
    Mississauga,Ontario(CANADA)
    Alright guys, I've got a little bit of rust in the corner of my car, and im not sure how i should fix it. I dont want to go out and buy huge parts, any ways i can get rid of the rust without replacing the door?
  2. deth101
    deth101 Senior Member
    usa
    cut and weld a new peice of skin in there but the whole door skin is probably the way to go .....then go to Zeibart and get the super rustproofing,its like 600$ but I drive every day in the winter and Iowa uses tons of salt but no probs whatever on my 95
  3. tab
    tab Super Moderator
    Aberdeen, Washington State
    How big is the rust, how deep, where EXACTLY? If you have holes, depending on size, I'd have them cut out. But if it's bad bad, look at new parts, new skin, or um, a new car. :ph34r:
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    bondo baby!!!!!!!!
  5. preludude
    preludude Member
    Rust sucks. I had to cut as much of the rust off as possible, then fiberglass resin on it and body filler to smooth it. And its been 5 months and I already see rust coming back. Damn. I hate honda rust.
  6. h22bubbleback
    h22bubbleback Senior Member
    North Jerzey
    :withstupid: bondo owns rust
  7. preludude
    preludude Member
    wont the rust come back in a year or so even with bondo?
  8. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    If you get all of the rusted metal cut out, weld in a patch panel and then bondo it it shouldnt rust for quite some time.
  9. tab
    tab Super Moderator
    :werd:
    All rust holes and scaly rust should be completely removed. The surface rust should be sanded off or rust converter used. You don't wanna paint over a turd. Take the time, and do it right. If done right, and painted properly, you won't see rust for years besides the occasional rock chip.
  10. JDMilan
    Boca Raton, FL
    or get another good condition panel from the scrap yard.
  11. preludude
    preludude Member
    See, what sucks though is the rear panel is a part of an entire clip. And that don't come cheap. I think now they use urethane for fender pieces to replace the cheap steel they used to use.
