Rust Removal
Discussion in 'Body / Exterior / Interior / Cosmetics' started by Ethereal, Aug 18, 2005.
  1. Ethereal
    Ethereal Junior Member
    I have a 91 crx and it has rust where the spare wheel normally sits. What can I do to rid the car of this crap? Thanks for your help?
  2. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    is it rusted completely through, or just surface rust?
  3. Ethereal
    Its just the surface area.
  4. CiViC_SOHC
    CiViC_SOHC Senior Member
  5. Taco15
    Tallahassee Fl
    sand it off and buy some ospho rust preventative. the ospho will STOP the rusting.
  6. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    there is only 1 way to get rid of rust cut it out and weld in a patch
  7. phyregod
    phyregod !!YTINASNI
    Central Texas
    OR, sand blast it untill there is NO rust left, and repaint.
  8. hcivic.com
    sand blasting is not 100% effective. Either and acid dip ( if you have the cash) or cut and weld
  9. Taco15
    Tallahassee Fl
    sand blast and ospho thats it!
  10. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    I forget what the shit was called, but I picked it up at Autozone when my Toyota's bed was rusting. Spray it onto rust and it chemically changes it into black paint (basically). Did that 4 years ago on all the rust in my bed and the rust hasn't spread nor come back. Check it out.
  11. old Skuul Hatch
    old Skuul Hatch Senior Member
    Honesdale Pennsylvania / Fort Smith Arkansas
    por15 or somthing i think
  12. driver1
    driver1 Senior Member
    as hcivic said theres only one way tro get rid of rust and thats to cut it out and weld in a patch. I dont care what kind of magic ina bottle u guys might think works....it doesnt
  13. wanderinman
    Raleigh, NC
    How many times have you used it. I've used it with great success, and everyone I know used it after it worked for me. Yet to find anyone who had anything other than great things to say about it. Its worth trying an $8 bottle to not have to cut and weld your car.
  14. hcivic.com
    ok folks last time in this thread i live in canada we have more rust tan you will ever see (primed parts rust in weeks) rust converts don't work 100%
  15. tab
    tab Super Moderator
    Aberdeen, Washington State
    :agree:
    Rust converters are for half ass or structural work that is 1/4" or thicker. That leaves a lot of metal to paint, and retreat in the future.
    If a panel has holes in it, then you should cut them out, period. If you cannot weld, then you should not be in the biz.
    Anything else is a band-aid, a patch, and however functional, still not meant to last in the long run.
    Driver1 and hcivic.com own this forum. Nuff said. I am just runner up to these boys in the bodywork world. Their word is gold. Shut up.
  16. Battle Pope
    If a body panel is rusted completely through, then sure I can see cutting and welding. However, if there's just mild surface rust I fail to see how cutting and welding is completely necessary.
  17. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    Mild surface rust often tends to be a hell of a lot worse than it first appears. If you start sanding on a spot that has bubbled up, say the size of a nickel... it will be pitted and corroded almost all the way through.
  18. teglovinvtec
    teglovinvtec Junior Member
    por15 is the best i love it use it its worth its weight in gold
  19. 92civicb18b1
    92civicb18b1 The Trisexual
    I also agree. Cut and weld.
    But the minor rust that was on my shitvic wasn't bad enough where I needed to cut and weld. It was very minor surfaace rust, I sandblasted that bitch and primed it up.
  20. tab
    tab Super Moderator
    yeah, if you have something blasted, or grind/sand until the rust is gone without blowing through, then it is just surface rust. Surface rust is easy enough to take car of.
    Sorry Swanny, I forgot to list your name too.
