S13 Rim Choices??
Discussion in 'Other Vehicle Discussions' started by JDMilan, Aug 10, 2004.
  1. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    Ok, looking to see if you guys came across with any decent rim selections, and no I will not convert to 5lug.
    Looking for 17" rims,
    My lug pattern is 4x114.3, and looking for an offset in the +35range since it's common.
    So far just pretty much came up with the 17" 5zigen FN01R-C's in Front 17x7.5 +40, and 17x8 +35 in the rear. These rims run around 200 a pop so that isn't such a bad idea.
    B, I am sure you have some decenet choices??
    thanks guys...
  2. pissedoffsol
    actually, no.
    there's dick for rims in our size man.
    its either:
    -go 5 lug
    - get cheap ass wheels with FWD offsets
    - spend an ass load of cash on volks
  3. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
  4. pissedoffsol
    yeah, volks. over 1400 for just wheels.
  5. JDMilan
    Boca Raton, FL
    whats your opinion with the 5zigens?? I mean they aren't that bad, and I would prefer them to be wider in the rear, but honestly for the cash involved it's not sooo bad :)
    also, some cat from freshalloy had custom made kosei K1's in the 4x114.3 pattern with a pretty damn good offset, and they ran him 250 a pop I think, he waited 10 weeks for them also.
    those gram lights would be pimp, but they are a little out of my price range. :)
  6. Battle Pope
    But they ARE teh sexay!
  7. JDMilan
    Boca Raton, FL
    ^^ I think these would look pretty damn good on a black s13 coupe,
  8. JDMilan
    Boca Raton, FL
    Heres a quote from another freshalloy member with these rims
    "S13 Setup:
    17x7.5 +25 Front 215/45 tire
    17x8 +15 Rear 225/45 tire
    H&R Hubcentric spacers w/ ext. studs 15mm F / 20mm R
    approx. 1.5 deg. neg. camber in front
    approx 2.5 deg. neg. camber in rear
    AGX's+Sportlines, slightly rolled fenders
    No rubbing; *uber* flush. "
    From 5Zigens site
    "Offsets are as recomended by 5zigen for the s13:
    SILVIA/180SX S13 17 x 7.5 +40 215/45-17 17 x 8.0 +35 235/40-17 "
  9. JDMilan
    Boca Raton, FL
    somewhat related to your other reply B:
    Honest Opinion
    is it going to be that bad with a +40 in front, and +35 in rear, if so like the quote above would you use spacers...
    I know it's ghetto, but thinking about it now??
  10. JDMilan
    Boca Raton, FL
    hmm........also on pdmracing they have a 5 lug conversion available
    Options include either using the H&R spacers, true 5 lug conversion from SE, or using the 5lug hubs which cost 300 for front and 220 for rear from pdm while retaining original equiptment.
  11. pissedoffsol
    s13 se's aren't 5 lug either.
    +40 sucks.
    might as well get a 17x7 tenzo wheel for a honda with the 8lug multi pattern. it will look the same way.
    7.5 / 8 setup is wack as fuck.
    you can easily fit a 10" wheel and a 245 no problem. plenty of guys run 255 in the rear with some cutting/rolling. 8 up front.
    i want 17x8.5/ 18x9.5
    but my car is too slow, and too ghetto to pull it off.... and thats a lot of money
  12. pissedoffsol
    oh, and that pdm kit is bogus. its still 4 lug
  13. JDMilan
    Boca Raton, FL
    thanks for the reply, I'll take your word for it......
