S2000 Boost + Nitrous
BlackJDMdeath
Ok, I am in the middle of a small debate here...
This is the current setup:
Garrett T3/04E Dual Ball Bearing Turbo (60 trim)
Intercooler
HKS BOV
HKS Wastegate (7lb Spring)
785cc Injectors (toned down at the moment but bought for compression change later)
3" Downpipe to 3" Test Pipe to 3" Custom Exhaust
Blitz SBC ID III Boost Controller
AEM EMS
AEM Wideband 02 Sensor
Nitrous Express 35 shot wet kit
Will the 35 shot be harmfull to the motor if ran on race gas (114 octane) and properly tuned through the EMS?
Thanks
it will be fine. nitrous does not = blow up ot of the box. as long as you tune it, and feed it through AEM's delivery, you should be fine. hell, run a 50 shot
DYNO with the juice on when you tune it though
Yeah, you should be OK, I would go as far as to say to get a 75 shot, if you want to push it, and/or you want to go that fast.
i think that a 75 shot would be much, a conservative 35 shot to spool the turbo should do just fine :)
you have to remember, a 35 shot on an FI car is pretty much like a 50-75 shot on an NA car.
Question..... I have never been able to get a solid answer on this.. maybe you guys might know...
What is the makeup of the internals? I have heard they have forged pistions and titanium rods... is this true? If so sounds pretty robust to me :)
B.
