S2000 oil change
Discussion in 'General Tech and Maintenance' started by GlassHeadlights, Mar 7, 2009.
  1. GlassHeadlights
    Calgary, AB
    It's about that time for the first oil change on my dads S2K.
    What oil and filter should he use?
    I was thinking of a bottle of royal purple and the rest synthetic oil. But I don't know what filter I should use.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    castrol and oem
  3. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
  4. GlassHeadlights
    Calgary, AB
    Is Royal Purple any good anyway?
  5. AHHVTEC
    Alabama
    myself i dont know, i would never use it lol
  6. Justin66
    Regular full synthetic should be just fine. Isnt it no different than bardhal or slick 50 or lucas oil and such? Unless your burning oil, which you shouldnt be, you will be fine.
  7. Korax
    Korax New Member
    Western PA
    OEM or Fram... since honda filters are fram filters... atleast here in the US idk about elsewhere. I do personally like the blue honda ones.
  8. MthaFuknGreen
    Lodi, CA
    go buy the cheapest gallon of oil you can find unless youre going synthetic.
  9. Ethan
    Ethan Well-Known Member
    I say oil is oil if your running stock. But i normally buy the good shit anyways.
  10. MthaFuknGreen
    Lodi, CA
    we just covered oil in class last week.
    its all the same unless its synthetic.
    people just pay for the marketing.
  11. AHHVTEC
    Alabama
    i just like using what honda uses.
  12. Ethan
    Cause honda is d-shiznit?
  13. MthaFuknGreen
    Lodi, CA
    cuz youre a fucking honda groupie.
  14. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Some instructors also say rotaries can rev forever, etc.
    Oils are not all the same; they have different compositions. Hit up Bobistheoilguy.com. All you can say is they have the same purpose.
    For oil filters; anything that doesn't fall apart will work fine. I prefer Wix and Wix-manufactured filters. I'm no longer using Mobil since the last few I've bought had metal shavings in them.
    Honda in US use to use something else besides Fram. The switch could be just to save cost. But if you're looking for the "performance" filter, get the S2000 one. IIRC, it's manufactured by someone else and is smaller.
  15. AHHVTEC
    Alabama
    cause im no da, and i know that all oils are not the same. go to a new school
  16. K2e2vin
    Raleigh, NC
    Heh, I didn't even read the OP.
    As far as RP goes, I personally don't like it. RP is great for making power since it's actually lighter than oils of similar weight, but breaks down just as fast as conventional oil. If you're going synthetic, just stick with Mobil. As far as I know, they're pretty much the top readily available brand.
    I myself use diesel oil(Rotella 5w-40 synthetic). :)
  17. Ethan
    lol hahaha
  18. GlassHeadlights
    Calgary, AB
    We're for shoure going synthetic.
    I think either a Fram or OEM filter because they're the easiest to find in town.
  19. K2e2vin
    Raleigh, NC
    I've just never liked Fram due to their cost-cutting methods/construction and design. If you're going synthetic, might as well use the OE S2000 filter or a Mobil filter along with Mobil 1 synthetic oil.
  20. eastbxc
    eastbxc Custom User Title
    Kansas
    I don't think so. I thought they were made by Hamp?
