speedy's hot sauce
Does anyone know if S2000 wheels will work on 2005 civic si? Bolt pattern seems the same , but the rear wheels on s2000 are bigger than the front.
conversionThoes civics were 5 lug in Japan? Or is that a conversion?
why only 4 fronts?? seem to work fine here
my buddies RHD coupe
]ok here the part number you need for 5lug conversion
REAR part
(Rear HUBS)
01 ITR = 42200-S03-C51
(Rear Rotors)
01 ITR =42510-ST7-R00
(Rear Calipers)
01 ITR=== 43018-S03-Z03 CALIPER SUB-ASSY., R. RR.
43019-S03-Z03 CALIPER SUB-ASSY., L. RR.
Front
Use
( 96-01 CRV B20 (non 4wd) )
you need to use
Rotor - Calipers - hubs - Spindels - soft Brake Lines .....
But using this setup you need to get B20 CRV 36mm Front part of axles and use GSR axles on any B Swap
