safe compression
Discussion in 'HYBRID -> EG-EK / DC' started by IntegraLS1995, Mar 26, 2004.
Thread Status:
Not open for further replies.
  1. IntegraLS1995
    IntegraLS1995 Junior Member
    whats the highest compression that some1 could run on an ls/vtec dailydriver?
  2. E_SolSi
    with really good tuning??? (if you have 93 octane readily available)
    probly around 13:1
  3. 97CTR
    97CTR Senior Member
    Yes you can run that high of a compression but around 12 or less would be more forgiving for a daily driver. Without knowing what you are after from your setup its hard to give advice.
  4. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    depends on tuning and what fuel management your planning on running, also what fuel you want to run, im assuming pump gas, i would actually run a little lower than the others are recoomending because in order to run that high on pump gas your going to have retard the timing alot, i'd play it safe and run 11:5-11:8 on a daily driver on pump gas
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    safe I would 12.1
  6. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    I would say 11.5:1 for street, unless you can aget 93 octane on a regular basis, then I would do 12:1 no more. And tuning and management is key, hondata for anything 11:5.1 and higher.
  7. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    Sunoco sells 94 octance in my town :thumbsup:
  8. E_SolSi
    calesta was running 12.6:1 daily driven
    im pretty sure he didnt have a hondata
    im guessing 93 octane (texas)
    he is/was planning on going even higher
    like i said with GOOD tuning i dont see why you couldnt run 13:1 with pump gas (93 octane)
  9. CRX_B16B
    CRX_B16B Senior Member
    speedway sells 110 in my town :worthy: but at $4 something a gallon I dont think so.
  10. IntegraLS1995
    im in cali so we get crap gas over here, and im gonna buy a hondata right after i get the ls/vtec done
  11. Bl6CRX
    UCLA
    yeah cali does have only piss 91, but some, i know of one and have heard there are others, Union 76's have 100
  12. JDMilan
    Boca Raton, FL
    93 in florida...holla..
  13. phunky.buddha
    Dallas / Fort Worth, TX
    Yup, 12.6:1 daily driven for 45k miles on 93 octane, VAFC only for tuning.
    Second build = 12.4:1 on 93 with Hondata at 13:1 a/f ratio, no problems
    Third build = 12.77:1 on 93, will run Hondata, shouldn't be a problem either.
  14. pissedoffsol
    This is not Swap-related. This is the Swap-related forum.
    Try again in the right forum.
    :locked2:
Thread Status:
