Sagging Front Passenger Spring
doofnoil
I recently installed some h&r sport springs and I've noticed that the passenger side front sags about a half an inch lower than the other springs. When I installed them the I tighened the strut bolt more on them to achieve the correct torque, and if you look at both the front shock towers, there is more thread coming from the passenger side than the drivers side. What's the problem? Can I just lossen the bolt on the passenger side to equal the thread length on the driver's? Also the front of the car seems to jounce a bit when I hit a dip on the highway.
fronts and rears are usually different ... are you 100% sure they are all in the right spots?
hmmmm
i guess double check that they are all seated properly
