I have the opportunity to pick up a complete B20a5/5 speed/half shafts/spindles/arms/etc with ecu for 200 bucks. It has 112k on it and has receipts for timing belt change at 109k. I am interested in it as a swap into my sand rail. My question is how hard it is going to be to make it run without the complete in-car harness. He has the full dash and dash harness with inst cluster which would be nice to monitor the gauges with, but no ecu harness. The engine has the full harness on it. Can I make this happen? The car with engine won't weigh much over 1000 lbs, so even though the B20s aren't the strongest engines, it should be plenty powerful and hold up fine. What are your thoughts on this? Should I try it? Can I find an ecu harness or at least the connectors? Thanks for any and all input-
Jeremy
Jeremy
