Script kiddies help me
Discussion in 'Computers, Games, Electronics etc' started by spectacle, Jun 23, 2005.
  1. spectacle
    spectacle Senior Member
    St. Petersburg, Fl
    I have a batch file that starts a kixscript. Without getting into too many details, I need this script to run continously as it updates a number of files that used for load balancing 3 antivirus servers as people log onto the network. The loop command doesn't work...script crashes and errors out. I tried running a scheduled task on one of the antivirus servers and had it run the script every minute, but its not working. I don't think it likes running batch files across network shares.
    Here's the kixscript:
    Code:
    ;**** NAV_Count.kix ****
    ;**** Created by Alan Jones on or around June 2005 ****
    ;**** Administrator Rights to NAV servers required!!! ****
    ;**** NAV_Count.kix is used to update the SAV "count files". ****
    ;**** When a user logs onto the domain, the logon script   ****
    ;**** reads the count files to determine which server to   ****
    ;**** use. This script must be run by an administrator, or ****
    ;**** as a service (scheduled task) run by an administrator. ****
    ;**** Reads client counts from the SAV servers ****
    $Nav1clients = Val(ReadValue("\\fsnvzrnav1\HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\LANDesk\VirusProtect6\CurrentVersion\AddressCache\FSNVZRNAV1", "NumberOfClients"))
    $Nav2clients = Val(ReadValue("\\fsnvzrnav1\HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\LANDesk\VirusProtect6\CurrentVersion\AddressCache\FSNVZRNAV2", "NumberOfClients"))
    $NavCclients = Val(ReadValue("\\fsnvzrnav1\HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\LANDesk\VirusProtect6\CurrentVersion\AddressCache\FSNVZRWNAVC", "NumberOfClients"))
    $NavMedclients = Val(ReadValue("\\fsnvzrmnav\HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\LANDesk\VirusProtect6\CurrentVersion\AddressCache\fsnvzrmnav", "NumberOfClients"))
    ;**** Sets variables for "Count Files" ****
    $Nav1count_File = "\\ffnvzr02\netlogon\nav1count.txt"
    $Nav2count_File = "\\ffnvzr02\netlogon\nav2count.txt"
    $NavCcount_File = "\\ffnvzr02\netlogon\navCcount.txt"
    ;**** Turned Off - Begins permanent loop ****
    ;while $Nav1count_File = "\\ffnvzr02\netlogon\nav1count.txt"
    ;**** Uncomment to make it display the counts ****
     MessageBox ("NAV 1 count: " + $Nav1clients + Chr(10) + "NAV 2 count: " + $Nav2clients + Chr(10) + "NAV C count: " + $NavCclients + Chr(10) + Chr(10) + "NAV Med count: " + $NavMedclients,"NAV Count")
    ;**** Writes count from NAV1 to NAV1 Count file ****
     Del $Nav1count_File
     Open(1,$Nav1count_File,1)
     Close(1)
     IF Open(1,$Nav1count_File,4) = 0
      $w1 = WriteLine(1,$Nav1clients)
      MessageBox ("Write worked: " + $Nav1clients,"NAV1 Count")
     ENDIF
     Close(1)
    ;**** Writes count from NAV2 to NAV2 Count file ****
     Del $Nav2count_File
     Open(2,$Nav2count_File,1)
     Close(2)
     IF Open(2,$Nav2count_File,4) = 0
      $w2 = WriteLine(2,$Nav2clients)
      MessageBox ("Write worked: " + $Nav2clients,"NAV2 Count")
     ENDIF
     Close(2)
    ;**** Writes count from NAVC to NAVC Count file ****
     Del $NavCcount_File
     Open(3,$NavCcount_File,1)
     Close(3)
     IF Open(3,$NavCcount_File,4) = 0
      $w3 = WriteLine(3,$NavCclients)
      MessageBox ("Write worked: " + $NavCclients,"NAVC Count")
     ENDIF
     Close(3)
    ;**** Sleeps for 15 seconds then checks counts again - only needed for looping ****
    ; Sleep 5
    ;loop
    Everything commented out was used for testing but for one reason or another was turned off. HELP!
  2. spectacle
    St. Petersburg, Fl
    anyone?
  3. pissedoffsol
    while i know nothing about this language's syntax...
    looks like you're trying to loop, but the program doesn't know where to begin the loop.
    for example
    Code:
    while x = true
      do stuff
    loop
    i see nothing of the sort in your script.
  4. spectacle
    St. Petersburg, Fl
    the while do loop is in there...
  5. pissedoffsol
    i still don't see it... lol but if you says its there... i dunno. i don't know this language.
  6. spectacle
    St. Petersburg, Fl
    you probably didn't see it because it was commented out. somebody HELP!
  7. erikespo
    erikespo Senior Member
    Western New York
    Try moving your while statement.. maybe at the very beginning.. or turn the whole thing into a function and then put the while on the function and loop that
  8. erikespo
    Western New York
    add a "do" after the while line
