Scripting/UNIX help
Discussion in 'Members' Lounge' started by lswhitecivic, Jun 14, 2013.
  1. lswhitecivic
    lswhitecivic Senior Member
    DFW, TX
    I know there are quite a few IT guys here, so I'm sure some have more experience working in UNIX than I do.
    Here is my problem:
    Once a week I have a cronjob that runs to check the indexes on our Unidata database for corruption.
    I didn't build this script, I just know what it does.
    When the job runs, it creates a file in /tmp called index.err.
    # more index.err
    PHANTOM process 28579 started.
    COMO file is '_PH_/root23402_28579'.
    Inside that file, I get the name of the actual phantom process that runs. If I browse to _PH_ directory and view the root23402_28579 file that has all the information I need to see related to the index checker.
    I'd like to create a cronjob that will email me the contents of that file. I can easily use a mailx command to send the email, but the problem is that file name will change every week.
    Do any of you know how I can extract the file name in a variable to then call when I do my mailx command?
    Hopefully that all makes sense. Let me know if you have any questions.
  2. lswhitecivic
    DFW, TX
    I'm thinking I'll need to do something like this:
    cat /tmp/index.err | grep root
    That gets me the line I need, but I don't know how to capture only the file name in a variable.
    This is probably a super easy script for someone well versed in UNIX, but I unfortunately am not.
  3. reikoshea
    Dallas, TX
    filename=`grep 'COMO file' index.err | cut -f2 -d\'`
    Will return _PH_/root23402_28579
    If you dont want the directory:
    filename=`grep 'COMO file' index.err | cut -f2 -d\' | cut -f2 -d/`
    if you're not familiar with cut, it will set a delimiter (-d) and then the -f will set which field you want.
    for example if you've got a line that is "/mnt/media/debian" and you wanted to cut off the "/mnt/" section you could do this:
    echo "/mnt/media/debian" | cut -f2,3 -d/
    Hope that helps
  4. lswhitecivic
    DFW, TX
    Awesome! That worked perfectly, thanks man!
    Here is my completed script.
    #This script sends the weekly index check log file to be reviewed.
    #!/usr/bin/ksh
    PATH=$PATH:/opt/perl/bin:/usr/contrib/bin
    export PATH=$PATH
    CREATEDATE=$(date +%x)
    filename=`grep 'COMO file' /tmp/index.err | cut -f2 -d\' | cut -f2 -d/`
    cat /sb/SB.EXC/_PH_/$filename | mailx -s "Index Check for ${CREATEDATE}" *email address*
    I knew it had to be easy for someone with more UNIX experience than me. :)
  5. reikoshea
    Dallas, TX
    you might want to start the script with this:
    Code:
    if [[ -r /tmp/index.err ]]; then
        exit 0
    fi
    That way you dont get a blank email or one that just says file doesn't exit. Just does a clean exit if /tmp/index.err is not readable or doesn't exist.
  6. reikoshea
    Dallas, TX
    Code:
        exit 0
    fi
