sensor on transmission??
blasterman87
theres a sensor on my 89si tranny it has 2 wires that plug in sepiratly and i cant figure out what it is, and what to do with it for my b16 i just put in.. should i put it in the b16 tranny somewhare or just loop the wires?? it would be nice to know what it does/is..
it's either the VSS or the reverse switch (what triggers your reverse back up white lights)
oh.. how can i tell what it is and do i need it on the b16 tranny? if its revurse light id need it i guess so whare do i put it..?
see the thing hangin there.. thats the reverse switch
umm.. look at the pic.. shows you right there... thats a b16 tranny
on the B-series transmission, the reverse switch is on the bottom - the transmission in the picture above appears to be a CG transmission from 86-89 Integra, not a B16
