the_crazy_russian
well I finally have my new built motor installed and I'm down to hooking up my last sensor. now comes the problem, old motor was a 99 y7 and the new motor is an a6. there are two sensor on the back of the block one with a single prong plug (oil sensor?) and another sensor right next to the single prong sensor. this sensor has two prongs (I beleive it controls the fan), this is the one I need to rewire. my y7 had a different connector which will not connect to this sensor.the y7 connector has three wires comming out of it, I'm assuming one wire can be discarded but I'm not sure which one.and for the life of me I can not find my manual with the wiring diagram.does any one know which two wires I need to use?
Thanks for your time,
B
B
