Sensor Under Oil Filter On H22a?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by afterburners, Feb 24, 2003.
  1. afterburners
    afterburners Junior Member
    Where does the sensor and wire go to that is under the oil filter in the jdm h22a. The wire is yellow/red and it is not in the diagrams?
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Knock sensor?
    Check a pinout diagram for where it goes. It's on the D plug, I just can't remember exactly which one.
  3. afterburners
    no, I think that is the one above the oil filter... not the one underside of it.... hhmmmm
  4. dohcvtec_accord
    The left lane
    Shit, I don't know then. I'd have to get under my car and have a look.
  5. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    my guess is oil pressure, you have to tap into that when doing something like an lsvtec
  6. boostdlude
    boostdlude Member
    should definitely be oil press. there should only be 2 sensors on the back of the block. above filter knock and below pressure. pressure has one wire attached with small phillips type 1 screw.
  7. BlackJDMdeath
    Wichita, KS
  8. D See 2
    D See 2 Senior Member
    Baltimore, MD
    i know this Q is for a H22a but on my old D16a6 it was like this.
    if it has one wire, its oil pressure
    if its the two wire sensor, its the coolant temp sensor.
    if its above the oil filter and one wire and vtec, its knock sensor.
  9. afterburners
    hey thanks! but what pin on the ecu is there [oil presure]
