SERIOUS HELP!!!!!!!
Discussion in 'HYBRID -> ED-EF / DA' started by BLKWDW, Mar 13, 2004.
Thread Status:
Not open for further replies.
  1. BLKWDW
    BLKWDW Member
    My 89 civic gives off white smoke so today after doing an oil change on my hatchback I applied the requirements of 250ml of BARDAHL NO-SMOKE. After I let it run of about 15 mins, I put it in first an drove forward. while my attempt to drive forward the engine seems it wants to shut off. so then i put it reverse and the engine struggled and turned off but it was a bad shut off and smoke started to come out of my short ram intake...IM SOOO PISSED!!!
    PLZ HELP.
  2. brian11to1
    brian11to1 Senior Member
    Sounds like rings man. Do you have a swap or anything? Good luck. Sorry to hear another ones bite the dust from ill-care techniques.
  3. BLKWDW
    BLKWDW Member
    NO swap it's the stock d15b2...like i dont get it how is smoke comming out of my damb intake system
  4. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    What kind of oil did you use? How many miles are on your car bud?
  5. BLKWDW
    BLKWDW Member
    oil- new penziol
    kilometers - 237000
  6. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    the same thing happend to my dx and i had a blown head gasket hence the white smoke
  7. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    with that info id say the rings or headgasket...any water in the oil or oil in the coolant?
  8. MXDesa
    MXDesa Senior Member
    Queens, New York
    Its your head gasket, rings rarely go on honda motors just like that, or any motor for that mater. 100% head gasket, i've done me 100's of times on hondas
  9. Doomster9
    Doomster9 Member
    I dont think that the headgasket alone would allow smoke to come out the intake plentum. Do a compression test on all cylinders, sounds like you might have an intake valve(s) not seating correctly which would explain the smoke coming out the ram-air-intake. Then check your headgasket...
  10. crx
    crx Senior Member
    cali near sac
    did this happen before? how much oil did you put?
  11. hybrid4
    hybrid4 Senior Member
    Nashville,TN
    HEAD GASKET, the same thing happened to me a couple of months ago. :thumbsup:
  12. GSRCRXsi
    MD
    This is not Swap-related. This is the Swap-related forum.
    Try again in the right forum.
    :locked2:
Thread Status:
