then how exactly did mike hook up his scan tool and find out that it was throwing a code for the bank 2 downstream O2 sensor?????????You can't even scan them.
I don't want that. I want the code.
sounds like this is an oem defect, maybe they will fix it free of charge.in fact... heres the technical service bulletin addressing this issue
http://www.bmwmotorsports.org/pdf/120704.pdf
If it was a recall, it would be on a Bulletin.
oh look O2 sensor codes"Service Engine Soon" light is illuminated and some of the following oxygen sensor faults codes may be stored in the DME fault memory
On a customer complaint basis only, clear fault memory and reprogram DME using DIS CD 38.0 or higher
