Sexy Welds
Discussion in 'Forced Induction' started by jimboburgess, Jan 19, 2007.
  1. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    Check out my downpipe, i guess this is called a whitey bend (from homemadeturbo) and the manifold all finished, i decided to route the wastegate back into the exhaust so it would pass inspection, thank god all we have around here is a visual imspection. I also made the that wacky 7 bolt flange that attaches to the turbo, it blocks off the stock wastegate.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    that looks like shit,
  3. jimboburgess
    nyc
    awesome shit, the pipe bender at the shop doesn't make bends that tight, only option i had without waiting a week to get manderl bends.
  4. get_nick
    Washington State
    your car is hating you right now...
  5. AHHVTEC
    Alabama
    well grind down the welds and it might clean up just a little
  6. eg6sir
    those look a little chunky.. not saying i can do better, but .. yea
  7. jimboburgess
    nyc
    1000th post
    isn't going to change the flow characteristics, already grinded the inside, i don't mind if it looks bad, less time killing my ears with an air powered die grinder.
  8. klyph
    klyph Dismember VIP
    North Pole, AK
    Turn the wirespeed on your welder down a tad, it will make your welds look a LOT cleaner. But I guess you're already done so it doesn't matter much.
    As long as nothing leaks, I say it looks great :thumbsup:
  9. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    You take a lose bend and cut it? Fuck is it that hard to get 2 shit bent? If it is maybee I should get into.
  10. jimboburgess
    nyc
    that is true, i like how it looks shows ingenuity and craftsmenship, doesn't need to look pretty to go fast and it'll function the way i intended
  11. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    THe welds look like crap. BUt who cares. Just make sure it doesnt leak
    Great job making your own dp. LOW BUDGET STYLE...i like that:worthy:
    Good luck with your project.
  12. dappa1
    dappa1 New Member
    Queens, NY
    looks like the piping has a fungus infection :eek:
  13. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Grind that shit down man. The functional budget looks is fine, but you're pushing it here :lol:
    When are you going to install all the new parts?
  14. TurboMirage
    fuck grinding it down, i dont really bother unless i think something is going to leak, then i can weld over it! ahaha!
    +1 for home grown ingenuity, regardless of what it looks like.
  15. jimboburgess
    nyc
    i got and installed the turbo rebuild kit, so by wednesday i hope to have all except the oil and water lines. once i have those installed it is a matter of tuning for the 11psi that the wastegate is set at, as my car sits it has a tune for a much smaller turbo with much less psi.
    grinding and rewelding isn't something i have time for with classes and trying to do this build all at the same time, i also have to manage a social life somewhere in there and playing in a regional band.
  16. jimboburgess
    nyc
  17. Turbo&Auto
    East Burg, PA!
    I wouldnt try running that car on the same map. Definately going to be VERY lean.
  18. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    way to go on he helen keller welds! but yeah i'd spend the time on it to grind them down...it'll look better. but hells yeah man, great job!
  19. klyph
    klyph Dismember VIP
    North Pole, AK
    hellen keller welds :lmao:
  20. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
