shaved door kit
Discussion in 'Body / Exterior / Interior / Cosmetics' started by Boondock Saint DX, Jul 14, 2005.
  1. Boondock Saint DX
    Boondock Saint DX Senior Member
    Des Moines, Iowa
  2. Boondock Saint DX
    Des Moines, Iowa
    sorry for wrong forum
  3. TurboMirage
    it might be a bit easier to swap over to EX coupe doors first, them put this kit in.
    then you also get power windows and mirrors :)
  4. 5thGenLuvin
    5thGenLuvin Senior Member
    Dude, I used Power door lock silenoids from a 85 Oldsmobile Calais to do my poppwer conversion:p It's a simple task, it really is. You need a power and ground, with a button, a monkey could wire that in 15 minutes. As for mounting it you will have to dick with it a bit if you don't but a "kit", even then there's prolly some tampering to do. Instead of connecting the selinoid to the door locking arm like you would if you were using for power locks you attach it to the door latch actuator instead... then get any stereo place to wire your power/ground into your alarm on one of your auxilary buttons and voila...!
