shaved head
Discussion in 'Engine Building' started by custompainter, Mar 30, 2009.
  1. custompainter
    custompainter drive it like U stole it
    central CT
    i was wondering what would happen if a shave a couple thousands off my LS head... and if it is a good idea how much should i take off??
    I have to head at work right now.. ripped down for a valve job and it would be nothing to mill a few off the top
    any info is welcome
  2. MthaFuknGreen
    Lodi, CA
    youd get higher compression.
  3. custompainter
    central CT
    yes and how much would be good to take off
  4. LsTec
    LsTec civic525whp
    out side philly
    Cheap HP! it works, but for how long is the question!....
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    i would only shave it if it was needed, just enough to make it good and straight
  6. disableddan
    disableddan Crazy Insane
    Edmonton Canada, Eh?
    ...or you might just go shit-nuts ^^^^
  7. efhondakid
    Akron-Canton, Ohio
    :werd:
  8. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    well talk to the machinist about what would be a good number........keep in mind that compression will go up, and its actually making your engine less reliable you really shouldnt get it done unless you have warped head
  9. custompainter
    central CT
    so i took 20 thousands off and from what i caculated it is going to up the compression half a point wich over all will be a 3% horse power gain ....
    wich doesn't realy equal anything maybe 5 to 10 horse
  10. disableddan
    ^Hey man, when you're going for all out power every 3% counts!!
  11. efhondakid
    Akron-Canton, Ohio
    Next thread: My pistons are hitting my valves, what should I do?
  12. MthaFuknGreen
    Lodi, CA
    double up the head gasket.
    duh.
    :D
  13. GlassHeadlights
    Calgary, AB
    I would've gotten different pistions.
  14. www.Head-Mechanics.co.uk
    www.Head-Mechanics.co.uk New Member
    what would the point be on skimming the head to raise compression and then double the gaskets. This will just cancell each other out. DUH.
    also dont get to close to the valve seats as the heat will distort the seats and cause missfire. Your better or decking it.
    IMO.
