Shaved taillights
Discussion in 'Body / Exterior / Interior / Cosmetics' started by SolidDreamz, Sep 1, 2003.
  1. SolidDreamz
    SolidDreamz Senior Member
    va beach,pa,oh
    Anyone know a good site on how to do molding and shi%? I wanna shave my back tailights off my civic thats on my trunk. Wanna learn how.
  2. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    Learn how do weld first :thumbsup:
  3. jamesA
    Good advice. lol
    Exactly what do you mean by you want to shave your taillights? <_<
  4. snowboarderguy44
    snowboarderguy44 Member
    So-CaL Riverside
    you will need to measure and cut a piece of metal if you want to shave a section that large. Make sure the metal is not too thin, since it will have to support a small amount of weight. have it heli-arced to the trunk. then go over it with a hand-held belt sander to remove the weld lines. word of advice tho dont worry if you still have the outlines of where your lights used to be.
  5. BodyDroppedNikes
    caught in a mosh...
    1. remove taillights
    2. sand down paint to bare metal around where the tail lights were (to make a good weld).
    3. weld a piece metal same size as tail light holes
    4. grind down welds so they are smooth with the body
    5. use body filler to fillin any holes or dents
    6. sand smooth
    7. primer
    8. sand some more
    9. paint
    thats pretty much it. if you dont know how to weld, find someone that can and have them do it. i hope thathelps ya out some.
  6. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    when your welding it weld small portions at a time maybe 1/2 beads and alternate where your welding so you dont get all the heat concentrated in one are warping it, cause the more you warp it the more mud your going to have to use and the more mud the better chance of shrinking, cracking and sandscratches showing up.
