Shaving b16 rods
Discussion in 'Engine Building' started by b16coupe, Jul 11, 2005.
  1. b16coupe
    b16coupe Senior Member
    anderson, S.C.
    I am planning on putting a set of ctr pistons in my b16, but after doing a little research i find out that you have to shave some of the rod for the ctr pistons to fit. what part do i shave off and how much do i take off? I have also read that the ctr pistons will give me 10.8:1 or 11.1:1 or 11.6:1 CR. Which is it?
    Thanks
  2. phunky.buddha
    Dallas / Fort Worth, TX
    I'm getting 10.8:1 compression through the calculator... I'm sure I'm doing something wrong though. I don't see why you'd need to shave the rods any.
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    its around 11 i believe. go on ff-squad.com (look for a tech section) from what ive seen, they have the most accurate b-series calculator and even have articles on the R pistons.
  4. K2e2vin
    Raleigh, NC
  5. reikoshea
    Dallas, TX
    i have it at 10.88:1 with p30 (JDM CTR pistons if memory serves)
    DOH!!!! CHECK REFRENCE SECTION
  6. hybrid89
    hybrid89 thistownsucks...
    SoCal
    p30 is the sir II pistons...CTR's are PCT
  7. reikoshea
    Dallas, TX
    oh okay thanks for the correction.
  8. eater_eg6
    eater_eg6 Junior Member
    yah...im planning to change my ori piston(b16a2) to ctr piston .... n someone tell me that hav to shave the rod too... but dunno which part of rod hav to shave actually... thanx.. need help here too... :(
  9. b16coupe
    anderson, S.C.
    http://www.ff-squad.com/tech/pistons/B16%2B17rodmod_1.jpg
    K2e2vin's site is a good resource
  10. phunky.buddha
    Oh- shaving THAT... thought you were talking about notching the rods or something.
  11. eater_eg6
    ya...i got it... thanx ya.. :)
  12. b16coupe
    anderson, S.C.
    Yep, i did originally too
  13. sohcslammer
    sohcslammer Senior Member
    Bay Area
    Just for reference - you also have to do this to LS rods to fit "R" type pistons on them.....
  14. b16coupe
    anderson, S.C.
    Do you have to get a maching shop to shave it perfectly flat or can you just do it yourself with a dremel or some other tool?
  15. K2e2vin
    Raleigh, NC
    well you shouldnt try doing it yourself unless unless you have some sort of milling machine or some sort of planer. a dremel isnt going to be too accurate and can probally ruin the balance. also, ive never really seen anyone try to shave steel with a dremel(only cut, so i dont know if there's even a bit for that).
  16. phunky.buddha
    :werd:
    Take it to a shop.
  17. b16coupe
    anderson, S.C.
    I just got back from 3 different machine shops and none of them can shave my damn rods. I don't see what balance i would be messing up if i did it myself with a grinder or something. How will it throw the balance off?
    Thanks
  18. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    Well if you don't get them all shaved EXACTLY the same it'll throw off the balance of your engine and boom, no more engine. With a grinder you can't do precise machining like you can with a mill. I mean, you can try it yourself, but I sure as hell wouldn't.
