Shaving molding
Discussion in 'Civic and del Sol - EG and EK' started by thatcivic96, May 12, 2009.
  1. thatcivic96
    thatcivic96 New Member
    Is this very hard, I popped off my side molding today, have about 6 months experience with bondo/fiberglass. Any tips would be much appreciated. 96 civic 2dr.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well the proper way is to weld up the holes, then skim with bondo
  3. thatcivic96
    so sand, weld holes shut, bondo as normal? Then would you lay fiberglass over the bondo just to be safe or no?
  4. AHHVTEC
    Alabama
    naa no need for fiber glass just weld then bondo
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    You'll want to cut little biddy squares of metal that fit into the holes, then tack weld them a little bit at a time (to prevent over heating and warping the surrounding metal). Done well, once the metal is all ground down and sanded out, you won't need bondo.
  6. thatcivic96
    Well going to try to work some magic this weekend, let you guys know how it turns out=D
