SWAPPED_94CIVICVX
i put a new tranny in my 94 civic vx with a z6..i took the shifting linkage off the tranny side..i popped the pin out and put the linkage on the new tranny i think i may have put it on wrong..any one have a diagram on the propper way the lkinkage should be put on....i might have to pop the pin out and twist the bar 180 degrees..!!!will a bad throw out bearing make it hard for a tranny to go from gear to gear?when i shift into gear its like it does not go all the wat in ..i have to be at about 4 grang to shift into third and sometimes fifth.thanks for the help
