Shift Linkage Help On 5g Civic
95a2civic
i noticed when gettin ready to hook the stock linkages up to my manual b16 swap that my linkage that bolts to the side of the tranny seems to be too short, but the one that does the shifting seems to be fine, can i just lengthen it??? thanks!!!
well you should have also noticed that the stabilizer bar and the actual shift rod are on opposite sides...
so you can lengthen both and bend them and make them twist around each other to get it to work.. i did it as a temporary fix while my DOHC del sol linkage was on backorder...
you'll need someone capable of welding...
mine is a 94 del sol Si.
if you have a hatch then you want integra shift linkage
and if you have a sol, then you want del sol VTEC shift linkage... it must be from the DOHC VTEC del sol
