Shift Linkage Problems
Discussion in 'General Tech and Maintenance' started by hunter4life, Nov 13, 2007.
  1. hunter4life
    hunter4life Rotary Man
    Canada
    Hi I got a 92 gsr off a friend with a little front end damage for a $1000 which i thought was a great deal (came with exhaust,headers,tailights and a deck) Anways I started the swap in my 92 civic dx with an si engine. I pulled out both engines and when i put the gsr engine in my civic and connected all the wires, etc I went to hook up the transmision and found out the shift linkage doesn't work. So I thought I would take the transmision from the integra but that didn't work either. The civic is hydraulic while the gsr is oldschool and has the cable set up. Which I thought was wierd so if anyone can help me that would be great.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what kind of si motor did you civic have in it a sohc d series or a dohc b series
  3. hunter4life
    Canada
    I think a dohc(newbie) does that matter
  4. AHHVTEC
    Alabama
    yes if your car still had the stock motor in it your gona need a few things new linkage for a b seires, and a few motor mounts, if its dohc it will say just that right on top of the valve cover
  5. AHHVTEC
    Alabama
    your also gona need a new tranny or convert your car to a cable/hydro style
  6. hunter4life
    Canada
    alright thanks, guess ill have to spend a couple hours doing some custom work.
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    do not hack together a shift linkage...if you have the money buy a hasport mount kit...and ebay has an AVID RACING shift linkage for cheap
  8. hunter4life
    Canada
    Thanks I'll figure out a way maybe its better just to get that kit your talking about. Anyways thanks for everybody's help
  9. norcalgsr
    NorCal
    Shortening and re-welding a shift linkage definitely is not 'hacking together' a linkage as long as you are able to do it right. What do you think all the aftermarket linkages are? A shortened version of the OEM linkage.. it's not hard to weld a couple pieces of pipe together.
