Shift linkage proper fit?
Discussion in 'HYBRID -> ED-EF / DA' started by 88blacksi, Oct 17, 2007.
  1. 88blacksi
    88blacksi Grandpa
    I have a integra spec type r shift linkage in my crx with b series swap. It doesn't fit and the seller said its a bolt on. Has anyone actually cut it and welded it back. What were the measurements to cut? Thanks.:)
  2. 88blacksi
    88blacksi Grandpa
    Anyone have any idea. I looked here on hondaswap and none about custom MADE one. All is buying hasport ones. Any help will be very much appreciated.
  3. norcalgsr
    NorCal
    You'll have to shorten it and weld it back together, but I don't know how much you need to take off.
  4. 88blacksi
    88blacksi Grandpa
    I do not want to guess? Anyone?
  5. norcalgsr
    NorCal
    Why don't you mount it in the car and measure the amount by which it is too long..
    Or better yet research stuff before you buy it and then you wouldn't have the problem in the first place.
  6. 88blacksi
    88blacksi Grandpa
  7. 88blacksi
    88blacksi Grandpa
    And REAL advice will be very much appreciated?
  8. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    You didnt look very hard! Really, I think it is like 2 3/8 inch of each piece. Like norcalgsr said mount it and make your measurments. It could be different depending on what mounts you used or you could just buy aftermarket linkage.
  9. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    This is the best I can find... Shortening the shift linkage
    Other places say that the mount kit determines how much to cut off. Some kits sit the motor closer to the firewall, closer to the crossmember, or dead center like the HaSport kit. If you have the HaSport Kit, then 2 3/8 inches is correct. other than that, you're gonna have to measure it.
  10. 88blacksi
    88blacksi Grandpa
    Thanks man b16racern2nr you are my hero unlike ase dude
  11. norcalgsr
    NorCal
    :bash:
    :fuckyou:
    What's wrong was making a simple measurement and cutting/welding some pipe too hard for you?
  12. B16RacerN2NR
    Moving back West...
    that's what i'm here for :D I just happened to come across your thread the one time this year I decide to check out the tech sections lol :ph34r:
  13. 91_civic_si
    Wasilla, Alaska
    I guess you just cant please everyone
