Shift Linkage Roll Pin
kingwilly
how do i get that roll pin out of the shift linkage/i been hittin with a punch and hammer but its not movin..help
spray it with some PBblaster or some other sit and find a flat ended bolt or punch that covers the whole pin but fits in the hole then hit it with a hammer..... you dont want something with a taper
good luck
its not movin for shit...can i drill it out and get another pin??
naw dont..just spray alot of wd-40 and wait a little...i did a swap and mine didnt come out that easily..it took me like an hour under the car...but it will come out w. the right punch and some time..if all else fails i guess drilling would be next..heating it up works too..
Originally posted by pills_PMD@May 26 2003, 05:39 PM
dont be a pussy when you hit it.
just thought i'd re-iterate this thought as it is true.
hope you didn't bend the shift shaft.. If you get a heavy hammer up on top of the shaft to back it up, the pin comes out a lot easier.
i used an 8mm punch and hammer worked like magic...hehe..no bends here brother
Amazing how easy stuff is with the right tools,huh?
