werd, they don't call it the "bitch pin" for nothing.
make sure you use something prefct in size- too big wont bang it out, too small will crush it (its very soft metal). tap lightly...
Are you removing the motor from the car? If so, are you using a lift? You can undo the bolt that holds the torque rod (one that bolts to the outside of the tranny), and take it out with the motor, then you have more room to remove the bitch pin.
