Shift Linkage
redxcobrax
God member
I am swapping a LS motor (b18a1) into my 94 civic eg. Do I need the LS shift linkage or the civic shift linkage?
I'm assuming its the civic shift linkage that I need, but I'd like to confirm.
Anyone? The teggy linkage is a bit longer so that's probably why you need to shorten it a bit right? But a civic linkage should just work (plug and play type?)
nope the civic linkage wont work. the connections to the trans for both the shift linkage and stabilizer bar are completely different. not only are they at different angle between the two diff trans types, but the stabilizer bar on the b-series is set much further back on the trans case.
d-series
b-series
either that or the b-series into eg linkages that are ready to go out of the box
