Shift Linkage
Discussion in 'Civic and del Sol - EG and EK' started by porkfried83, Apr 25, 2011.
  1. porkfried83
    porkfried83 New Member
    ME
    I have a 95 DX, with a D15b7. I'm taking out the motor and can't get the shift linkage out of the transmission. I pulled the boot back and took off the clip and what looks like a spring pin will not come out! Anybody have any idea on what to do?
  2. Briansol
    this is called the 'bitch pin' for obvious reasons. just take a nail/etc and hammer it up. it's just tapped into place and should come out the top.
  3. stoopidb18eg
    stoopidb18eg New Member
    Yeah I had that problem on one of the tegs I had. Easiest way is a drill and bit. You can buy the pins @ autozone
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just finished taking a bitch pin out about 15 min ago. ive tried tons of ways but what ive found to work the best is an air hammer with the chisel bit ground down to slightly smaller than the bitch pin hole. one squeeze of the trigger and its out.
  5. Briansol
    The 14mm power steering mounting bolt works mint. its long enough to hold, and its got a rounded cylinder shaped top that seats right inside.
  6. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    that or a trans bellhousing 12mm bolt..
  7. GlassHeadlights
    Calgary, AB
    I use a screwdriver bit identical to this one. Worked every time.
  8. B16
    B16 Super Moderator VIP
    yay area, CA
    I use a punch
  9. porkfried83
    ME
    I got the bitch pin out, after I detached the other end of the shift rod and took the motor out with it still attached and then took a screwdriver like what GlassHeadlights recommended and pounded the hell out of it and she came out....I didn't have enough swinging power underneath the car.
  10. Briansol
  11. E_SolSi
    i use profanity and anger lubricated with man juice
  12. dc4dude
    dc4dude Member
    chicago, il
    a 1/4 inch ratchet extension works awesome for me... at home... at the shop, the air hammer works wonders... and breaks shit...lol
