Shift Linkage
Discussion in 'HYBRID -> EG-EK / DC' started by redhatch92, Mar 21, 2003.
  1. redhatch92
    redhatch92 Member
    New Jersey
    will 00 b16a2 shiftlinkage work if i decide to get the b18b trans, also can i use the b16a2 o2 sensor with a b18b engine
  2. E_SolSi
    i think you need to use a 3rd gen integra linkage .... not sure if the Si one will work
    an O2 sensor is an O2 sensor ... as long as its the same style (# of wires) it will work
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Depends on what car your putting it in,in a civic,yes in a sol,no.The o2 it depends on the number of wires other than that I'm not sure.
  4. redhatch92
    redhatch92 Member
    New Jersey
    I HAVE A 92 CIVIC HATCH CX, SO IT WILL WORK AND FIT CORRECTLY WITH MY 95 LS ENGINE AND 00 SI TRANS OR 95 LS TRANS NO MATTER WHICH TRANS I USE. THE 00 SI HAS A 4 WIRE O2 AND IVE BEEN TOLD THAT ALL 92 HATCH'S WERE PREWIRED FOR A 4 WIRE O2, ALSO WHAT DO YOU THINK ABOUT USEING A USED 00 SI CLUTCH. I WORK IN A SALVAGE YARD SO A LOT OF THE PARTS I HAVE WERE FREE. BUT I WILL SPEND MONEY TO GET WHAT I NEED. MY GOAL IS TO LEAVE WHAT EVER I CAN HONDA OEM. THANX
  5. hondacivicnos
    hondacivicnos Senior Member
    Well all I can say just go to SWAP section for Civic 5th generation.
    I dont know about your problem.
    But if you swapping B18c1 or B18C5 in 92-95 Civic shiftlinkage Civic SI 99-00 will work fine.
