Shopping For A New Cat
Discussion in 'Civic and del Sol - EG and EK' started by nplsdvr, Jul 23, 2008.
  1. nplsdvr
    nplsdvr New Member
    B'ham, AL
    98 civic ex - d16y8
    CEL is giving me a P0420 code (Catalyst System Efficiency Below Threshold)
    1. does that absolutely, positively mean bad CAT? Could it be a bad sensor (secondary o2 sensor, right?) in the CAT? How could I test the difference?
    2. shopping for a new CAT - every website seems to have the same stuff and the same price range: $131 - $550. How do I know I'm getting the right one? I'm pretty sure I want the one with the "2-Bolt Welded Type Inlet, 3-Bolt Welded Type Outlet" just for simplicity sake, but what about brand? There's Eastern, Cato, Magnaflow, DEC, Bosal, etc. etc.
    Any suggestions for brand or where to get it? Any advice what to look for or avoid?
    Thanks!
  2. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    I would personally go for OEM, unless you wanted aftermarket. Try checking out www.hondapartsonline.com That's Majestic Honda. They have some good stuff there. Best of luck and also, let me know what you find. I "may" have to replace my cat when I build my Y8 and turbo it.
  3. eg6sir
    if not replaced by OEM i'd go with a magnaflow high flow or catco .. basically the same thing
  4. nplsdvr
    nplsdvr New Member
    B'ham, AL
    Majestic was the first place I looked - not a cat on the list.
    *NQO'TD: How do I know an OEM cat from an aftermarket cat? Or any other part for that matter? Brand name = aftermarket? How is an OEM part listed?
    Thanks, Luis998
    *Noob Question O'The Day - I claim "Noob Immunity" :p
  5. eg6sir
  6. nplsdvr
    nplsdvr New Member
    B'ham, AL
    Thanks eg6sir!
    That is one that's going to have to be welded right? That one doesn't come with the "2-Bolt Welded Type Inlet, 3-Bolt Welded Type Outlet" does it?
  7. eg6sir
    any muffler shop could weld some flanges on it for $20-25
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
  9. robertbergl
    robertbergl New Member
    Georgia
  10. 91accordwithwork
    91accordwithwork kid that everyone loves!
    Wauwatosa WI
    haha i (above)
    i think my cat is going to
    if i have a perfromace exaust but a stock cat, would a magaflow fit everything if i got one? because im not sure the size of the stock in and outlets?
  11. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    beat me to it.. i was going to post that when i saw the title.
