Shopping List
the_rail
hey everyone,
Im just about to purchase a b16a1 complete swap from my friends at JDM Source Canada which includes the following:
Engine
Transmission
ECU
Alternator
A/C
Power Steering Pump
Distributor
Wiring Harness
Now my question is what other parts will i be needing (ex: mounts, shift linkage, etc.) if anyone here has done the swap, please help me out.
thanks,
karl
Mounts and shift linkages. A smaller battery may help, like one from a 92-95 Civic. 90-93 Integra upper radiator hose, 90-93 Integra lower radiator hose. Timing belt and water pump (order these for a 99-00 Si or 96-97 Del Sol VTEC). Valve cover gasket set as well. Order for a 99-00 Si or 96-97 Del Sol VTEC. Put all this other stuff on before hte engine goes in, its a hell of a lot easier.
HEy karl how much do you get it for ? IE im from calgary to have already got into 2 engines from them. Do you hang around beyond at all
New clutch, plugs, plug wires, Shift linkage bushing (and a new bitch pin would be useful), rear tranny bracket (90-93 teg), if its a CRX HF you need Si or DX hubs, 90-93 integra axles, distributor cap and rotor (replace), and lots of anger management!!!!
