Short Shifter Q
Discussion in 'General Tech and Maintenance' started by CRX-YEM, Feb 4, 2003.
  1. CRX-YEM
    Wallingford, CT
    OK, I've got my skunk2 shifter, and new bushings etc..
    how long do you think it will take to install this stuff
    a rough estimate will do. I wanna do it this sat. was just tryin to figure
    out if I'll have time to do it. Thanks in advacne
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    no more than 2 hours a buddy and I did it to his car and we were phucking around the whole time and did it in 2.5 hours.
  3. Sirhc2013
    Sirhc2013 Member
    Ocean City NJ
    It should only take an hour if you dont fuck around its a very easy install.
  4. 2fastaccord
    2fastaccord Senior Member
    Yea, and hour to an hour and a half sounds correct if you don't screw around. One of my bros did his in an hour by himself.
    Peace*
  5. Jeef
    Jeef NO MA'AM Moderator VIP
    An hour at the most. If I didn't have to work on Sat I would help you. I think that you have to leave the shifter in 5th before you take it out so it goes back in properly. I could be wrong as I have not swapped one in a while. Make sure that you have some vice grips to help hold the bolt that holds the ball in the place.
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    yes, no more than an hour, very easy to do... i'd reccomend letting the car cool down for a min, dont know how EF's are but on EK's its right there :) i love my skunk2 ss, enjoy!
    EDIT: i meant to say the exhaust is right there, where you do the work.... i was pretty baked last night, sorry :p
  7. pissedoffsol
    yup- do it cold.
    remove shift knob
    jack up car on 4 jackstands if possible, else 2 on the front as high as possible, as you will be in the middle of the car
    unbolt the shit- you might have to remove the exhaust from the hangar
    remeber how the shift linkages look...
    repeat above backwards after you put the new one in :)
  8. aznhottiekj
    aznhottiekj Senior Member
    i have installed a short shifter about 4 times
    the first time took me 1 hour n a half,
    now i can do it in under 1 hour,
    you just have to get the order of removing the bolts right or it just gets awkward removing them
  9. aznhottiekj
    o yea,
    i noticed that guy gave you a walk through,
    you might wanna also take off ur heat shield that sits right under ur shifter console, i noticed it rubs a bit in 5th gear if you dnt remove it,
