Short throw shifter
Discussion in 'General Tech and Maintenance' started by Slow&Delirious, Mar 1, 2009.
  1. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    I would like any feed back that anyone has about short throw shifters
    from what i can tell from research it allows for less movement between shifts because it gives diffrent leverage angles on the linkage, but takes more effort to shift
    so if anyone is using one or has opinions about them i would like to hear about it
  2. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    nope easy to shift, they are normaly the same hight as stock just a shorter distance from gear to gear. I have a 40% in my crx and its waaaaaaayy better!
  3. Slow&Delirious
    Boonville NC
    thanks, any one had any bad expirence with and aftermarket throw shifter?
  4. CRX-YEM
    Wallingford, CT
    I have and preffer the Skunk2 short shifter.
  5. OGMatt
    vic B.C. Japanada
    Bad thing: shift linkage rubs against exaust in reverse.:ph34r:
  6. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    I did, kinda. My left leg couldn't keep keep up with the speed of my arm shifting when I had a short shifter. I would grind gears every so often at the drag strip so I pulled that shit out, put the stock one back, and no more grinding issues :)
  7. eg6sir
    stay away from cheap aftermarket ones off eBay.. IMO.. find a OEM Type R shift lever and use that
  8. OGMatt
    vic B.C. Japanada
    I got an APC ss off ebay and its good quallity
  9. !JDM_EF-9!
    !JDM_EF-9! I'm just EF'n..
    cailfornia
    but the shifter linkage rubs against exaust in reverse??:dunno:
  10. efhondakid
    Akron-Canton, Ohio
    I rocked an egay shifter in my EF for some time, then I made my own from the stock shifter the ebay one was super light aluminum making it not very balanced that is the only problem I had with it.
  11. OGMatt
    vic B.C. Japanada
    ya there is a little 3inch counter weight and in reverse hits and vibs. on the exaust. I just have to cut it but I dont care about it really.
  12. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what car
  13. goldgreen90ef
    goldgreen90ef goldgeen90ef
    cold ohio
    stay away from cheap short throws, they can make your shit grind..(i had a ebay one) skunk2 or oem type-r (thats what i have and love!)
  14. Fernpatch
    Fernpatch Member
    Bellingham,WA
    I have a B&M straight stick pro shifter in my crx and love it. much better than the ebay crap I had in my old hatch.
  15. 99sidude
    Ohio
    I had a b&m in my old civic si. I really see them as somewhat of a gimmick. Yea it was cool the shifter only moved a few inches during a shift, however my car now has the stock shifter and I've never once thought it was a long throw or grinded gears.
    We're lucky with how good our shifters are stock. My maxima is atleast double the throw of my civic. Ever driven a taraus sho? It's like pulling a sloppy e-brake lever every time.
  16. INJEN78
    INJEN78 HS LEGEND
    OHIO
    apc ebay shifter in my hatch and transferred it to my rex,worx fine for me,and i slam gears,wish it was heavier though..ive heard the Skunk2 with skunk2 weighted knob is the best shift yet
  17. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    blox makes a shifter that is near copy of the skunk2 but for alittle less cash and the weight knob is great
  18. squeals
    squeals New Member
    Charlotte, NC
    I had someone tell me that BLOX is almost a complete replica of Skunk2 because the owners or BLOX used to work at Skunk2 or something. i don't know anything about that but i have a Skunk2 shift knob and it's the same as a BLOX. I.M.O, getting a nicely weighted knob will do wonders.....
  19. Slow&Delirious
    Boonville NC
    95 del sol s, its the DD and if i like the throw shifter i was thinking about getting a brand name one for the civic. the one i got was off egay, 12 bucks, if it sucks i will sell it for 20 and if it works thats great.
    win win
  20. AHHVTEC
    Alabama
    your 01 civic is a cable shift. so it will be different. as far as the 01 civic goes get a comptech you will love it.
