Should i get it(f22 block )
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Alexyc, Jul 7, 2009.
  1. Alexyc
    Alexyc New Member
    Hey guys, new to this forum and i have a question , i have a chance to get ahold of a f22(vtec) engine from an accord i believe,I do plan on boosting my h23 in the near future.and since it cost 800+ to get it sleeved ,should i just buy the f22 block since it dosent require to be sleeved(and i should be able to get it for cheap) for turbo.And if i were to buy it, should there be anything you guys recommend changing or swapping like internals from my h23 block to the f22 block??? (only reason i even thought about doing swap because i was told it pretty much a bolt on process,if im misinformed please correct me) the f22 motor came from a 96 or 97 vtec accord, he said he will give me the block for $50.
  2. hondakidd03
    hondakidd03 New Member
    Fort Worth, TX
    I say go for it, ive been researching this engine for a g22 (f22block/h22 head) build and it will do good with boost plus you can put ur h23 head on the f22 block and you have dohc.
